abs and traction control idiot lights are on
Old 07-27-2015, 09:25 PM
abe's Avatar
abe
abe is offline
Default abs and traction control idiot lights are on
My '09 Lacrosse has the ABS and TC idiot lights on all the time. I can't get them to go out. I thought I had found the solution to the problem when I found no continuity on the green wire that goes from the right front wheel unit to the plugin by the brake system. Every other sensor wire had continuity, so I spliced in a new green wire on just this one. I momentarily unhooked the battery to reset everything, and then went for a drive. Still the 2 idiot lights are on. I have checked resistance on all 4 wheel sensors. I show about 1.4 ohms give or take on all 4, which I am told is good. I see no hanging wires anywhere. I assured myself that all connections are good with my ohmmeter. When I shut the car off, the message on the dash says "check ABS system" and then "Traction control off", to which pushing the TC button makes no difference. It still stays off. I believe that the problem is on the front wheels, because I have the TC light and the car is front wheel drive. I've only used TC once since I've had the car. Wife says get it fixed. Help!
abe
Old 07-25-2017, 08:35 PM
B737doc's Avatar
My 2010 LaCrosse had "check stabilitrac" and "abs" light on intermittently. Took it to Advance auto parts, they read the code with a code reader (lights were off at the time), said the right front wheel speed sensor was bad. Had one in stock for $27, changed sensor (very easy), lights have been out since.... HTH
Gary Fogg
12-12-2012 03:10 AM
stfaustina
08-04-2011 03:55 PM
CAR DUMB
04-01-2011 03:26 PM
CAR DUMB
03-30-2011 10:36 AM
Quick Reply: abs and traction control idiot lights are on
