Starting problem on 02 Rondezvous
Old 08-03-2006, 01:58 PM
rickr's Avatar
Hi everyone, I have a 02 Rondezvouswith 42 kms on it. It won't start unless you let it sit for 20-90 minutes after it has been running and hot. I do not hear the 3 second hum of the fuel sending unit at the intial turning of the key. All I hear is a slight pop sound. After waiting for the vehicle to cool down It will start and I obviously hear the normal hum of the sending unit,but if I engage the key on and off in quick succession,just to the point where the sending unit hums ,it will get weaker and slower then eventually not work again unless I wait again for the vehicleor defective partto cool down.
I have looked on the web for help but can't find any similarities. I get the feeling this could be a costly trial and error buy replacing ,sending unit,body control module,ignition control module or ignition relay. ...Can any of you help me and what would you do?
....Thank's for your time...Rick
Old 08-14-2006, 04:10 PM
Patrick's Avatar
Administrator
i have heard of a similar issue, but not on a rendezvous...it was a crank sensor issue in one case, and in the other, it was the ECU.
sherwoodpark
05-14-2015 09:04 AM
bnhsdad
10-28-2011 06:09 AM
nakno002
07-03-2011 08:04 AM
dhender
07-12-2009 11:11 PM
BurntCornMuffin
06-20-2005 01:51 AM
Quick Reply: Starting problem on 02 Rondezvous
