BF Help & Suggestion Center Need help with BF? Ask... Have a suggestion to better BF? Tell us here...
2000 LeSabre dies after startup.
Old 03-18-2010, 08:09 AM
nhawlman's Avatar
Default 2000 LeSabre dies after startup.
160,000 miles with newish Fuel Filter.
It starts right up, then dies within minutes.
Then it acts like it wants to start, but doesn't
unless I let it sit for an hour or so.
When it repeats the performance.
I suspect the fuel Pump.
How do I test it?
Any other ideas?
Thanks,
Nevin
Old 07-01-2015, 08:40 AM
jbh00buick's Avatar
Replace the core packs. I had the same problem. I had to sit for awhile until the bad core packs de-energize. Also check the crank shaft sensor and the PCM
Old 07-01-2015, 08:43 AM
jbh00buick's Avatar
Also with the car off, have someone turn the key to the acc position not start while you listen under the car where the gas tank is, check to see if you hear the fuel pump engage.
Deeupholstery
01-27-2015 08:08 AM
Chuck S
02-18-2012 05:21 AM
jlm2519
01-17-2012 08:12 PM
kdcing
05-03-2008 10:42 AM
wingnut691983
10-10-2006 01:55 AM
Quick Reply: 2000 LeSabre dies after startup.
